[Mk4 Golf] ARL glow plug fault code po684 - TDI & Diesel Forum - uk-mkivs
Mk4 Golf
1 reply to this topic
#1 Chippyba
Chippyba
  • 2 posts
  • Uk
  • Golf IV GTI 1.9 ARL 150PS
Posted 21 September 2020 - 06:46 PM
Hi peps got a fault code for my ARL pd150 po684 glow plug to pcm static.
Done a simple glow plug test with a multimeter(positive probe on the positive of the battery n then checked the voltage through the glow plug via the negative probe,all reading 12 volts,) but also checked the harness like this and got a ground reading through the harness of 12 volts through all 4 glow plug connectors,also checked the plugs on the water heater,the plugs were good as got battery voltage n also checked the harness there n got no ground reading through that part of the harness for the water heater glow plugs,I've searched Google for answers but keep drawing blank about this
Tia
#2 Chippyba
Chippyba
  • 2 posts
  • Uk
Posted 21 September 2020 - 07:59 PM
Quick update done a continuity test from the loom plug up to the module under the skuttle I've got a ground continuity from engine earth to each pin on the plug up to the module
