Heavy blue smoke on startup pd130 2003 - TDI & Diesel Forum - uk-mkivs
3 replies to this topic
#1 Andrew0808
Andrew0808
  • 7 posts
  • Hertfordshire
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 11 October 2020 - 10:54 AM
Hi
I have a ongoing issue with heavy blue smoke on cold Start
I have recently replaced my turbo after it let go and broke the shaft
I cleaned all intercooler hoses flushed intercooler and check intercooler pipes they are clean and clear of oil?
Also just changed injector seals thinking this might be the problem
It starts lumpy heavy blue smoke then when you drive away it's clears and drives pefect no smoke at all
Then I can stop and start all day with no problems
Until I start the next morning and blue smoke
Have done alot of digging and now think Poss tandem pump???
Oil level seems to be slightly rising?
I am totally lost
Can anyone help me
  • Andrew0808 likes this
#2 northpole
northpole
  • 9831 posts
  • Suffolk
Posted 12 October 2020 - 05:56 AM
could be tandempump seal needing a replacement...replacing the seals isn't hard
could be engine valve seats needing replacement... the latter is found by doing a compression test.
#3 Bandit127
Bandit127
  • 187 posts
  • Southampton
  • Golf VI SE TDI 2.0 140PS
Posted 12 October 2020 - 04:17 PM
For the 5 minutes it takes, scan it for glow plug problems before diving in to bigger jobs. This usually causes white smoke not blue but the other symptom is a good fit for two or more glow plugs. If you can't/don't want to scan it then check the resistance. You should have about 3-6 Ohms to ground. Anything over about 8 Ohms is effectively open and anything under 1 Ohm is shorted.
#4 Andrew0808
Andrew0808
  • 7 posts
  • Hertfordshire
Posted 17 October 2020 - 04:53 PM
Ran vcds and had 1 code P0301 intermittent missfire cylinder 1??
