A/C and heating - Engine, Tuning and Performance - uk-mkivs
A/C and heating
2 replies to this topic
#1 locarno
locarno
  • 631 posts
  • Poland
  • Golf IV 1.6 16v SE AUS
Posted 11 October 2020 - 06:05 PM
Quick question. Does A/C still drying the air while I have set 100% hot air ? From what I see the Evaporator is behind the flap when we set hot air so it does not work ?
#2 northpole
northpole
  • 9934 posts
  • Suffolk
Posted 12 October 2020 - 05:55 AM
when the a/c is switched off you disengage the a/c compressor, that is what turns it off.. the rest will than act as if it only has a heater matrix and fresh air control.
#3 bugsy_malone 666
bugsy_malone 666
  • 137 posts
  • Hampshire
Posted 23 October 2020 - 10:18 PM
I haven't looked at how the coils are laid out, but as long as the ac coil is before the heating coil, it will cool the incoming air in from outside, causing the moisture to drop out of the air, then the heater coil will warm the air back up again. That's how 'air conditioning' works, you adjust the moisture by cooling as required then reheat it. Which is why you have the ac on when you are demisting the windscreen, warm air will com out, but it will have had a lot of the moisture removed first helping it clear existing moisture.
Sent from my ELE-L09 using Tapatalk
