whats the highest capacity, most reliable battery you can use in mk4? - Audio, Electrics and Lighting - uk-mkivs
3 replies to this topic
#1 Karim
Karim
  • 857 posts
  • London
  • Golf IV 1.6 16v BCB 105PS
Posted 14 October 2020 - 04:09 PM
I'm doing amazon flex delivery with my golf. Effectively multidrop delivery, I want to ensure that I never hgave a dead battery, amazon tends to be higher mileage than other delivery work.
I'm just wondering what's the highest AH battery you can fit into mk4 golf?
#2 ttg4l
ttg4l
  • 859 posts
Posted 14 October 2020 - 05:34 PM
Not sure on the exact book capacities, but you can fit a larger battery than standard if you get a diesel battery tray/box and battery fit for a mk4 diesel. Petrol one is smaller.
Bosch do a 77ah type 096 battery which would fit the diesel tray. Can't confirm if you can go any bigger, someone else might be able to though.
#3 northpole
northpole
  • 9831 posts
  • Suffolk
Posted 16 October 2020 - 07:16 AM
I ran a 110AH battery on my diesel and it just about fitted in the battery-box, I did upgrade my battery-box to that of a PD130 and i had to modify the internals (shave some of the plastic off on the inside) to make it fit...  but i also upgraded the alternator to a 110AH one
#4 Bandit127
Bandit127
  • 187 posts
  • Southampton
  • Golf VI SE TDI 2.0 140PS
Posted 16 October 2020 - 08:37 AM
You could also monitor the level of charge in your battery. Voltage drops in proportion to % charge, once it gets below 30% you could give it an overnight charge.
Battery-state-of-charge-for-Wet-and-AGM.
