Mk1 Audi TT Cast Arms - Suspension, Brakes and Chassis - uk-mkivs
3 replies to this topic
#1 joe bora tdi
joe bora tdi
  • 58 posts
  • sheffield
  • Bora SE TDI 1.9 ASZ 130PS
Posted 18 October 2020 - 12:02 AM
Hi All
Just fitting Mk1 Audi TT cast arms new standard genuine bushes painted in black with nub drilled for drop links. My question is there is adjustability on the bottom ball joints which position should i set the bottom ball joints too ? I'm in a tdi bora lowered 30mm for info purposes.
Many Thanks
Joe
#2 northpole
northpole
  • 9833 posts
  • Suffolk
Posted 18 October 2020 - 07:47 AM
just put them on, put the bolts in so it allows for movement, then pull it out to the very end.... do the same on both sides than when you've done it all have the car aligned on a hunters machine... it makes it easier for when you have to work on the car again
#3 Imagewerx
Imagewerx
  • Moderators
  • 50114 posts
Posted 18 October 2020 - 09:07 AM
Your post has been moved.Always ask technical questions in the relevant technical section.The forum is laid out in such a way as to make them very easy to find.
#4 Aidymk4v520v
Aidymk4v520v
  • 253 posts
  • Nottingham
  • Golf IV V5 2.3 20v 170PS
Posted 18 October 2020 - 01:55 PM
Mine are set bang in the middle of the slot's, gives me roughly -1.2 Camber.
Sent from my IN2013 using Tapatalk
