Hi all,
Recently bought a 1.6fsi on a 57 plate. We have noticed recently that we are having to top up the coolant on a weekly basis. Today my wife went to drive it and said that the battery light has come on and there was no heating in the car. Can anyone point me in the right direction.
5 replies to this topic
#1
Posted 24 November 2020 - 04:12 PM
#2
Posted 24 November 2020 - 07:03 PM
No heating could be if an air lock formed when the coolant went low and you didn't burp the system when you filled it back up.
It's either leaking out, being burned or mixing with the oil.
For the battery light, test the battery and alternator. Can be done with a multimeter. Check battery voltage while the car is running, should be around 13.8-14v.
#3
Posted 24 November 2020 - 07:34 PM
Well I got home and have had a look. The belt is completely missing! Not sure what happened. Is it easy to put a new one on?
#4
Posted 25 November 2020 - 03:03 PM
Likely snapped and fell off somewhere.
Easy to swap, just don't lose any fingers when moving the tensioner. Pull tensioner back, slide allen key or drill bit into placeholder hole to keep it back, fit new belt and release tensioner. It will auto tension.
#5
Posted 25 November 2020 - 03:06 PM
I’ve just bought the new belt. Will fit it shortly. Does it matter which way round the belt goes? Just double checking
#6
Posted 25 November 2020 - 07:24 PM
It matters that you match up the ribbed side to pulleys that are ribbed. So for example if the belt goes over the top of one pulley then you need ribbed side down touching the pulley (assuming it's ribbed), and if it goes under a pulley then it'll likely be smooth so you need the smooth side touching the pulley.
If you're unsure then ask your local indie garage to do it, they shouldn't want more than £20 to fit it.
Technical Community →
VAG Diagnostic Software Discussion →
Golf mk5 Front fog lights codingStarted by KeiranLeigh , 12 Dec 2020 ![]() |
Audio, Electrics and Lighting →
Golf mk5 Front fog lights retro fitStarted by KeiranLeigh , 12 Dec 2020 ![]() |
Suspension, Brakes and Chassis →
Brake & Clutch FlushStarted by markmooch , 25 Nov 2020 ![]() |
Engine, Tuning and Performance →
2.0 TDi BMN 170 issues.. helpStarted by kiemcd , 17 Oct 2020 ![]() |
TDI & Diesel Forum →
Intake flap motor v157Started by Jake_bkd , 01 Sep 2020 ![]() |
