8 replies to this topic
#1
Posted 25 November 2020 - 08:50 AM
I’ve just replaced the ABS pump and want to flush the brake & clutch system entirely as it won’t have been done for years. Do I need a pressure bleeder and VAGCOM or can it be done by one person manually (pipe on the nipples, plastic bottle to collect fluid) with the engine running (to power the brake & clutch system)? The car is a 1.6 FSI.
Sent from my iPad using Tapatalk
#2
Posted 25 November 2020 - 10:27 AM
From what I understand is you need vagcom
If u don't then I'm guessing the only other way is to bleed as best as u can, then drive and stamp on the brakes to get the abs to kick in and rebleed again and again .
That's just a guess, I could be totally wrong
- markmooch likes this
#3
Posted 25 November 2020 - 12:41 PM
A regular bleed/flush can be done without a pressure bleeder, and that doesn't require the engine being on since it's just pushing around hydraulic fluid. But for this, I think the book calls for VAGCOM and a pressure bleeder, but I'm pretty sure I've read people have done it without either of those.
I used an eezibleed when I did my rear calipers and it was pretty rubbish imo, the pipes and cap never sealed properly which defeats the purpose of it being a pressure bleeder. So if it were me going fourth, I'd either attempt to bleed with the 1 man bottle method, or try a vacuum bleeder, can't get any worse than just not being bled at all after opening the system.
#4
Posted 25 November 2020 - 01:19 PM
Thanks pal, that’s disappointing to hear about the eezibleed. Any idea what size tube/line is needed to go over the brake nipple? Have some 8 or 10mm (I think) fuel line but it’s black so can’t view the change in colour of the brake fluid as easily when the clean new stuff starts to come through.
#5
Posted 25 November 2020 - 02:58 PM
Just buy some fish tank hose off eBay if you don't have any clear hoses. It's a few quid at most
#6
Posted 25 November 2020 - 03:01 PM
Not sure on exact size, but I think 8mm should be a nice, snug fit. The bleed nipples on calipers is an 11mm spanner, and the spanner can slide over the tube fairly easily, so I'd go 8mm if you've got it.
Ideally get some clear tube if you can though, makes it so much easier to see air coming out and clean fluid coming through.
#7
Posted 26 November 2020 - 12:24 PM
dude i will give you the best advise ever.... go to any universal garage (kwikfit, Formula1, garage on the corner) and pay them to do it for you yes bleeding isn't hard if you got 2 people you can do it the old fashioned way, but it takes forever... I actually had mine replaced last year at Formula1 and they used a bleeding machine... took them 20 minutes including bleeding the clutch slave cylinder and brake master cylinder best thing i ever did...
the last time i did it myself it took me hours doing it the old fashioned way
#8
Posted 28 November 2020 - 10:58 AM
Yeah they didn't do it in 20 minutes then. You'd be a solid hour confidently doing each caliper, providing the nipples all crack free.
#9
Posted 14 December 2020 - 08:24 AM
I didn't know you were there...
they did in in 20 minutes, i actually stood there and watched them do it... and this was on my daily vectra c.... the brake lines on that are a lot longer than on a golf mk4, the the callipers are bigger, and the clutch slave cylinder is a pita to bleed yet they managed to replace the brake fluid within 20 minutes... the machine they used was connected to the compressor so i figure the brake fluid got pushed in under quite some pressure...
Technical Community →
VAG Diagnostic Software Discussion →
Golf mk5 Front fog lights codingStarted by KeiranLeigh , 12 Dec 2020 ![]() |
Audio, Electrics and Lighting →
Golf mk5 Front fog lights retro fitStarted by KeiranLeigh , 12 Dec 2020 ![]() |
Mk5 issuesStarted by andy.stephens66 , 24 Nov 2020 ![]() |
Engine, Tuning and Performance →
2.0 TDi BMN 170 issues.. helpStarted by kiemcd , 17 Oct 2020 ![]() |
TDI & Diesel Forum →
Intake flap motor v157Started by Jake_bkd , 01 Sep 2020 ![]() |
