Water in passenger footwell - MkVII (MK7) Golf and Jetta - uk-mkivs
6 replies to this topic
#1 Kjohal1
Kjohal1
  • 34 posts
  • Lancashire
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 05 December 2020 - 12:37 PM
Hey folks
my dads mk7 (2014) 1.4tsi has got wet rear passenger footwells. I can see the water built up on the door seal and overflowing when I open the door.
is this likely the same issue that i have fixed on both my mk4 golfs whereby the seal on the door needs replacing or siliconing in as i have done previously. Or should I be looking for some other cause?
TIA
Golf GTTDI PD130 2003
Previous Golf GTTDI PD 115 2001
16 years in a MK4 and still going
#2 ttg4l
ttg4l
  • 934 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 06 December 2020 - 11:30 PM
AFAIK, for the Mk5 Golf onwards VW ditched that poor design of the metal carrier having a seal around it behind the door card, so the Mk7 shouldn't be affected. The only place I can think behind the door card that could leak is the speaker.
I'd be looking at rear light seals, tailgate seal or potentially a bad main door seal. Check for a build up of dirt on the rubber passage along the bottom edge of the door, that could be stopping the water from draining off the sill/bottom part of the door entrance of the car.
Check for water in the boot area.
  • Kjohal1 likes this
#3 Kjohal1
Kjohal1
  • 34 posts
  • Lancashire
Posted 07 December 2020 - 01:24 PM
Nice one
i take a look at all those and see what I can find
#4 ttg4l
ttg4l
  • 934 posts
Posted 08 December 2020 - 11:09 PM
Found this while searching for the source of my leak, figured it could be useful to you.
#5 Kjohal1
Kjohal1
  • 34 posts
  • Lancashire
Posted 12 December 2020 - 02:09 PM
Thanks Just Grazing - I used that video and me and my old man had a go this morning. Safe to say the speaker was the source of the issue and I could quite clearly see the spontex sponge which VW have used as a seal behind the speaker. Absolute plonkers in my opinion.
I cut away the sponge bits hanging out, dried out the area and then applied a slilcone seal around the rim. I know this is not ideal and it would have been better to remove the speaker but I didnt want to break the pop rivots so opted for the seal option. I did a nice tidy job and its now in the garage to dryout. I confident this will resolve the issue but I am rather frustrated at VW for such a poor effort on their part.
one bonus was i didnt break a single clip
#6 ttg4l
ttg4l
  • 934 posts
Posted 12 December 2020 - 04:36 PM
Glad you found it. They've used that sponge/membrane seal for years and it's always been rubbish.
Would advise lifting the carpet to dry the underlay/sound deadening out fully otherwise the car will smell of damp. That sound deadening soaks up the water like a massive sponge.
#7 Kjohal1
Kjohal1
  • 34 posts
  • Lancashire
Posted 12 December 2020 - 06:42 PM
Yeah it’s currently in the garage everything open and now drying out. The car mats soaked up a lot of the water but will do thattoo thanks for the tip.
