Running dual usb connections off 12v cig socket up front - Audio, Electrics and Lighting - uk-mkivs
8 replies to this topic
#1 IrishBen
IrishBen
  • 57 posts
  • Ireland
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 07 December 2020 - 02:47 AM
Hi,
I've tried this and i got it to work once, not sure if I blew box or is cause id to extend the input connections and when I finished extending the cable I might have put em backwards.
I've a new box coming but a buddy suggested I put an inline fuse or swap out the one in fuse box, which wasn't blown during my first attempt either, for a higher one? Mine current one is 15 , I tried with a 20 but still nothing..
Anyone care to offer opinion?
Sent from my SM-G960W using Tapatalk
#2 The_Moose
The_Moose
  • 237 posts
  • MKI Models
Posted 07 December 2020 - 07:10 AM
Hi mate, I fitted a usb socket into my centre console and it works fine
I fitted a piggy back fuse to cigarette lighter and ran the live from that and the earth to the boss under the steering wheel
#3 IrishBen
IrishBen
  • 57 posts
  • Ireland
Posted 07 December 2020 - 10:09 AM
Cheers for the advice, ill grab inline fuse and run the ground to the earth on column.7ceeca08e1ed823ee97f4199acedc53e.jpg06fb2d29591dfe75338f2fe225de3eda.jpg
#4 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 11065 posts
  • Glasgow
Posted 08 December 2020 - 11:00 AM
USBs draw about 0.5a per port.  Fast charging can draw upwards of 3A.  If you're blowing 15a fuses you have an issue.  Do not just fit a bigger fuse for Christ sake.
Does it blow with nothing connected?
#5 IrishBen
IrishBen
  • 57 posts
  • Ireland
Posted 08 December 2020 - 11:02 AM
It did not blow the 15a fuse for cig lighter.
Everything else still works cept those 2 ports I added in.
I tried with a 20a fuse but it didn't change anything so I swapped it back
#6 adam-
adam-
    VR6 GT35 4mo
  • 11065 posts
  • Glasgow
Posted 08 December 2020 - 07:11 PM
Replace the ports, likely dead.
#7 IrishBen
IrishBen
  • 57 posts
  • Ireland
Posted 03 May 2021 - 12:05 AM
And the final solution..
Run a separate wire from battery, fused 10A about 3" from terminal, thru bulkhead and terminate on a block. Ran separate ground from one on steering column to same block and then wired in my ebay special usb box and voila!
Now just gotta mount them to the blank plates and bond 35f1939329162aa004b9a72099b6be48.jpg045bc6e1dae4b7144f0b6e249d0d5c73.jpg96a7924aaab78831bf39fd32341c2614.jpg
Sent from my SM-G975W using Tapatalk
#8 adam-
adam-
    VR6 GT35 4mo
  • 11065 posts
  • Glasgow
Posted 03 May 2021 - 02:00 PM
What circuitry is below that?  USB is 5v, car is 12v.
#9 IrishBen
IrishBen
  • 57 posts
  • Ireland
Posted 03 May 2021 - 08:45 PM
Thats the DC step-down converter I bought and wired in. Beyond that I dunno what's inside itm I've a fair idea though.3e5638293fc7b7eab2cc49ad254bc451.jpg
