[Mk4 Golf] 1.6 AUS + ERT Gearbox grinding sound - Clutch and Gearbox - uk-mkivs
Mk4 Golf
14 replies to this topic
#1 Theallinner
Theallinner
  • 41 posts
  • Golf IV 1.6 16v SE AUS
Posted 07 December 2020 - 06:31 PM
Hello everyone again :) its been a while since i wrote something here. I drive my mkiv every day. I take 100 km / day on avarage. Some strange failing bearing "grinding" kind of noise started to show up usually when the car is in operating temperature. All i want to know is how far i can go with this lovely creature that takes so much in its twentys so that the wheels wont block while going in fifth gear or something? Now about the noise and why I'am asking this. Noise ONLY appears when the gearbox is in neutral and clutch isnt pressed in. And it only appears when the car is stopped completely, a very small movement in neutral will mute the sound. Car is stopped, i press in the clutch- noise is gone as well. At first me and my mechaninc thought that its a worn out clutch release bearing so we changed the whole clutch assembly (and found out that my Golf doesnt even have a thing called release bearing, its an old type clutch). And now after an expensive full clutch replacing the sound isn't gone.. This made me decide to buy an electric car that will end this kind of headache.. Im done spending money in it, i mean its old and everything eventually will fail. So my question now is how far i can go? Until i buy a new car? What is the worst scenario that can happen with input shaft bearing failure? At least i decided that this bearing is causing the noise. Patiently waiting for answers :)
#2 ttg4l
ttg4l
  • 1002 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 07 December 2020 - 07:49 PM
It does sort of have a release bearing, it's just not a traditional type, it's a capped type in the end of the box, under the green cap. Have you inspected it at all? And also the release arm which is under that green cap?
Do you have a video of the noise at all?
#3 Theallinner
Theallinner
  • 41 posts
Posted 08 December 2020 - 01:47 PM
I haven't checked that, neither my mechanic has. How hard is it to replace these components? Do i have to remove the transaxle? What will happen if i won't fix this issue? I will try to make a video later, because i'm not able to do this right now
#4 ttg4l
ttg4l
  • 1002 posts
Posted 08 December 2020 - 07:27 PM
It's much easier to replace those than to replace the clutch. No need to remove any axles or drop the box.
Remove the wheel arch liner on the passenger side and take the wheel off and you've got plenty of space to do it. Take a look at videos showing how to replace the release arm on a MK3 Golf, same process as the box on the 1.6 MK4.
Not the best video but it gives you a good idea, using a magnet to get the old release bearing out makes it a lot easier. You'll likely lose a little bit of gearbox oil when you open the green cap so have something to catch it and a little to top it up (can top it up through the reverse light switch hole on the top of the box if you want the easy fill option). Ideally you'd fill it from the fill cap till it drips out, but if you put the same amount in that comes out then it shouldn't be a problem.
Also ideally you'd replace the green cap with a new one.
  • Theallinner likes this
#5 Theallinner
Theallinner
  • 41 posts
Posted 10 December 2020 - 09:58 AM
Thank You for information, i just called another mechanic and told him about situation i have. He told me that it must be input shaft bearing :( i will still make a video, i believe he can be wrong
#6 Theallinner
Theallinner
  • 41 posts
Posted 15 December 2020 - 03:41 PM
Okay, so I have another question. What would happen if the input shaft bearing collapsed while i'm going ~50 miles an hour? How fatal it would be?
#7 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 11058 posts
  • Glasgow
Posted 15 December 2020 - 04:04 PM
The release bearing?
#8 DerPanzerWagen
DerPanzerWagen
  • 404 posts
  • Wales
Posted 15 December 2020 - 04:37 PM
Depends if there was a massive lorry up your rear doing 49mph or not...
Either way, you would have no gear or you'd be stuck in half a gear but your car wouldn't accelerate anymore.
#9 Theallinner
Theallinner
  • 41 posts
Posted 15 December 2020 - 05:17 PM
The bearing that is inside the transaxle
#10 Theallinner
Theallinner
  • 41 posts
Posted 15 December 2020 - 05:23 PM
So wheels of the car wouldn't lock up while driving in fifth gear so i cause an accident and crash my Golf?
#11 adam-
adam-
    VR6 GT35 4mo
  • 11058 posts
  • Glasgow
Posted 15 December 2020 - 07:11 PM
Inside the transaxle?
#12 Theallinner
Theallinner
  • 41 posts
Posted 16 December 2020 - 10:55 AM
I mean the gearbox. Well i tried to make a video today, but i could barely hear the sound my car makes on my phone. I will still upload it when i get back home. Now sometimes i can hear some kind of clunking noise, but its not permanent. And once again- it totally sounds like a bad bearing. It only happens when the car is still and in neutral, clutch pedal is not pressed. I press the clutch pedal- sound is gone. And when the car is moving in neutral the sound is gone too. Rebuilding the gearbox is expensive, buying a used transmission is risky. I dont know what should i do
#13 adam-
adam-
    VR6 GT35 4mo
  • 11058 posts
  • Glasgow
Posted 16 December 2020 - 10:58 AM
Are you sure it's not the release bearing?
#14 Theallinner
Theallinner
  • 41 posts
Posted 26 February 2021 - 07:23 AM
Here is an update, sorry for taking that long. Changed the release bearing (the old one was in a pretty good condition).The sound is a little more quiet, but it is still here. I'm guessing it's the input shaft bearing. :( But what about the fly wheel? Does it have a bearing in the centre?
#15 northpole
northpole
    I live here
  • 10280 posts
  • Suffolk
Posted 26 February 2021 - 08:21 AM
No you got a solid flywheel.
