V5 hot start issues - Engine, Tuning and Performance - uk-mkivs
V5 hot start issues
Best Answer jayartibee , 14 February 2021 - 12:42 PM
well the Trouble Code was actually correct this time. That's a bonus....
Go to the full post
12 replies to this topic
#1 jayartibee
jayartibee
  • 43 posts
  • ludlow
  • Golf IV V5 2.3 10v 150PS
Posted 10 December 2020 - 05:09 PM
Dear all -
fairly elderly V5 (10 valve) has developed intermittent non-start when hot. Have to wait about twenty minutes before it'll fire up (cranks nicely). Which is a bit boring.
What to check first do y'all reckon? MAF unit?
Jeremy
#2 northpole
northpole
    I live here
  • PipPipPipPipPipPip
  • 10175 posts
  • Suffolk
Posted 10 December 2020 - 08:06 PM
Vcds or the older vagcom... scan the ecu for faults it'll tell you where to start looking... but knowing the v engines 9 out of 10 times it's the coilpack or the coilpack regulator that causes the non start when hot.
#3 Imagewerx
Imagewerx
  • Moderators
  • 50170 posts
Posted 11 December 2020 - 06:07 PM
Your post has been moved.Always ask technical questions in the relevant technical section.
#4 jayartibee
jayartibee
  • 43 posts
  • ludlow
Posted 16 December 2020 - 01:54 PM
So where should I have asked a question about the engine not starting, if not in the engine section?
  • thinkpad likes this
#5 thinkpad
thinkpad
  • 523 posts
  • Golf V SE 1.6 FSI 115PS
Posted 16 December 2020 - 04:04 PM
This is one area I completely agree with you. This forum is unnecessarily sub-divided to the extreme that it is very confusing where questions should go even for regular users, never mind newbies.
#6 adam-
adam-
    VR6 GT35 4mo
  • 10983 posts
  • Glasgow
Posted 16 December 2020 - 07:50 PM
I think we just have to accept the gestapo we have.
#7 jayartibee
jayartibee
  • 43 posts
  • ludlow
Posted 22 January 2021 - 12:29 PM
There is a P0668 error code - temperature sensor fault - I think that may be connected? Someone mentioned dodgy wiring below ECU?
#8 northpole
northpole
    I live here
  • 10175 posts
  • Suffolk
Posted 24 January 2021 - 09:12 AM
you should check the wiring first yes, if that all checks out replace the sensor...  but as you also had the alternator problem chances are the lot is fine but the ecu jjust got random faults because of power not being sufficient...  I would start with replacing the alternator (you already bought a new battery) once that is done scan the ecu, remove all faults, scan again if there are still problems they will pop up, take it from there.
#9 jayartibee
jayartibee
  • 43 posts
  • ludlow
Posted 12 February 2021 - 02:48 PM
Turned out to be crankshaft position sensor. Started cutting the engine after about 20 minutes. Local indy replaced for £70 all in. Win!
  • northpole likes this
#10 davecqd
davecqd
  • 6 posts
  • london
Posted 14 February 2021 - 11:12 AM
You're lucky your Indy found it so quickly,  first time mine went it took Vag main agent nearly two weeks get a fix !!!
#11 jayartibee
jayartibee
  • 43 posts
  • ludlow
Posted 14 February 2021 - 12:42 PM   Best Answer
#12 adam-
adam-
    VR6 GT35 4mo
  • 10983 posts
  • Glasgow
Posted 14 February 2021 - 03:06 PM
Likely because they just scanned it, had a fault code and did that item.  Your garage sounds like they're A, busy or B, actually doing diagnostics.  If it only happens after 20 minutes, that doesn't leave a big window of diagnostics.
#13 18tjetta
18tjetta
  • 12 posts
  • West Midlands
  • Jetta S 1.4 TSI 122PS
Posted 18 February 2021 - 08:54 PM
Good tips
Sent from my YOTA 3+ using Tapatalk
