Long story,so make a cuppa.
If all you need is my solution to get all the air out of the braking system,scroll down to SOLUTION
A friend of mine called me one day,clutch had just gone to the floor.Ok,usual snapped clutch pedal i guess.
Nope,one of the circlips locking the clutch pipes in to the clutch bleed valve had broken in half allowing the pipe going from the bleed valve to the slave cylinder to wobble a little bit,leaking fluid.
Changed the circlip,bled the clutch but now couldn't get the bleed nipple to stay leak free.
Tried three used ones,all working fine in the cars they came from.But once we opened the nipple to bleed the clutch we couldn't get it tight again.
Got a new one,that worked.
However,had low biting point on the clutch and also a very long brake pedal.
Bled the system many times,vacuum,pressure,old school with a friend in the car pressing the brake/clutch,VCDS bleeding procedure followed,master cylinder bled,wheels bled in any kind of sequence you can think of,tried everything we could think of.No improvement.
Googled and googled,but couldn't come up with anything else to try,came across quite a few people that had given up and just lived with it.
Hmm.
SOLUTION.
One day remembered how i bled the brakes on a car about 25 years ago when i was a mechanic.This was,i think,the fairly early days of ABS where we had no way of activating the ABS with diagnostic equipment.
What we used to do was to take the car on to some slippery surface,gravel,wet road,wet grass etc etc.Slam on the brakes a few times and get the ABS to activate.
Did that with my friends Golf,the clutch immediately went back to normal biting point ???
Now the clutch,apart from sharing the the fluid reservoir with the brakes,is a separate system so how did activating the ABS fix the clutch ?
I have absolutely no idea,but it did.The ex-mechanic in me can not figure this one out.
Anyhow,went back to my friends house after activating the ABS,bled the master cylinder again,and hey presto,we had brakes again.
Again,how did activating the ABS get wherever the air was hiding,back to the master cylinder ???
Was there a small air bubble in the master cylinder that wouldn't bleed out until the jerking motion of the ABS wiggled it out to the bleed nipple so we could bleed it out ?
Anyhow,tried everything to bleed your brakes ? Try manually activating the ABS,it certainly worked for us.
Any comments on how this fixed the clutch or why nothing else worked are more than welcome,every day is a school day and this one is buggering me so i'm open to all ideas...
