Thoughts on rear wiper motor - Bodywork and Painting - uk-mkivs
1 reply to this topic
#1 elektrikbanana
elektrikbanana
  • 1538 posts
  • Lincoln & West London
  • Golf IV GTI 1.9 ARL 150PS
Posted 26 January 2021 - 03:17 PM
Hi all,
I've just replaced my rear wiper arm and blade a few weeks back to refresh things, I've also had a weak jet at the back for some time.
I took my rear washer nozzle off at the same time as replacing my wiper arm and found that it was blocked and had good pressure out the back of the car without a nozzle fitted eliminating a leak somewhere else.
I've fitted a new nozzle today but found it now spins with the wiper shaft.
Do you think this has seized by chance at the same time as I've fitted these new parts or it's something to do with my installation?
Both the nozzle and outer shaft seen here after the nut spins when wiping.
Just wanted some opinions before I replace the motor.
#2 seagull VW
seagull VW
  • 37 posts
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 26 January 2021 - 03:40 PM
Recently had this issue on mine and used the following to sort it
It's an easy, cheap fix - and really satisfying to do.
Good luck
