[Mk4 Golf] Turbo boost again - TDI & Diesel Forum - uk-mkivs
Mk4 Golf
Turbo boost again
4 replies to this topic
#1 teamonkey
teamonkey
  • 57 posts
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 21 February 2021 - 05:48 PM
Good day all !
Another boost issue !
The low down boost still seems ok but is totally flat when doing 70 then putting my foot down a bit to over-take. I've put my foot down further to test acceleration and there's nothing there.
So anything up to 2100revs and 70mph and the turbo seems normal but after that, nothing, feels like an sdi.
Another blockage ?
All ideas welcome.
1.9 TDI ASZ 2002 : 170,000
Turbo replaced : 30,000 miles ago.
Turbo manifold cleaned : 5000 miles ago or less.
#2 ttg4l
ttg4l
  • 962 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 21 February 2021 - 06:53 PM
Do a smoke test to check for boost leaks.
Any stored codes?
#3 northpole
northpole
    I live here
  • PipPipPipPipPipPip
  • 10187 posts
  • Suffolk
Posted 22 February 2021 - 08:22 AM
If you got no boost leaks and all the vacuum pipes are fine it might be one of the valves causing a problem... but who set the turbo lever? it might not be set right... that is if it never reached above 70mph since it has been replaced.
#4 teamonkey
teamonkey
  • 57 posts
Posted 22 February 2021 - 05:52 PM
OK thanks for the advice.
No checks performed yet, car has been above 70 no problem since turbo manifold was cleaned last summer.
I forgot - when the issue was experienced just over a week ago, the outside temperature was 0 - 1.5c but the car has been driven in such low temps before without a known issue.
#5 northpole
northpole
    I live here
  • 10187 posts
  • Suffolk
Posted 23 February 2021 - 08:06 AM
well the colder it is the easier the car should get up to speed, the colder weather makes for more oxygen in the compressed air... so that is no reason for it to slow down...
nope you might have a leak in one of your boostpipes, or one of the securing clips is loose enough for it to leak under boost or the one of the culprits given before...
