Brake force adjustment? - Suspension, Brakes and Chassis - uk-mkivs
7 replies to this topic
#1 locarno
locarno
  • 657 posts
  • Poland
  • Golf IV 1.6 16v SE AUS
Posted 25 February 2021 - 09:34 PM
Hi
Is there any adjustment for brake force in MK4? I mean adjustment like stronger or weaker braking while litle press brake pedal. I noticed that in the other mk4 pedal can act differently and I'm curious if this can be adjusted.
#2 ttg4l
ttg4l
  • 1000 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 25 February 2021 - 09:40 PM
You can adjust the brake booster push rod by tiny increments to change the point at which the brakes engage, if that's what you mean?
#3 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 11056 posts
  • Glasgow
Posted 26 February 2021 - 09:49 AM
Hi
It's because people can't bleed them properly so what you're feeling is air.  It cannot be adjusted.
#4 northpole
northpole
    I live here
  • 10266 posts
  • Suffolk
Posted 26 February 2021 - 12:10 PM
I agree with Adam-, what you are experiencing is either old brake fluid (it should be changed every 2 years as it's hydroscopic, soaks up moisture from the air) or badly bled brakes... so if i was in your shoes and you can't remember when the brake fluid was replaced, i would replace it... alternatively have it replaced... it's cheap enough and i've never had my brake fluid replaced to than have a problem of a spongy pedal...
#5 locarno
locarno
  • 657 posts
  • Poland
Posted 22 March 2021 - 02:17 PM
"badly bled brakes". You mean here air in the pipes?
#6 yurtesen
yurtesen
  • 1197 posts
  • Finland
Posted 22 March 2021 - 10:11 PM
If it is softer, it can be air. But also poor quality brake hoses perhaps can expand under pressure.
#7 Bandit127
Bandit127
  • 194 posts
  • Southampton
  • Golf VI SE TDI 2.0 140PS
Posted 23 March 2021 - 06:21 AM
Or a vacuum leak resulting in less vacuum in the servo.
#8 DerPanzerWagen
DerPanzerWagen
  • 404 posts
  • Wales
Posted 25 March 2021 - 05:55 PM
Braking feel in the pedal can be effected by:
- Pad thickness
- Air in the system by incorrect bleeding
- ABS pump on it's way out
- Condition of the brake fluid pipes
- Master cylinder leaking
- Water in the brake fluid
- Stuck or sticky callipers
- Never changing the brake fluid
- Running with low brake fluid
Could be any of those reasons why...
