2007 touran tdi dsg - MkVII (MK7) Golf and Jetta - uk-mkivs
2007 touran tdi dsg
No replies to this topic
#1 m1ler
m1ler
  • 157 posts
Posted 01 March 2021 - 05:47 PM
Hello vw gang, I'm back but with a touran 2007 tdi dsg this time my last vw was the mk4 golf 150pd , the touran has started to use coolant slightly no overheating and no obvious signs of hg, the temp sits at 90 as normal when driving/warmed up, I've replaced the reservoir thinking that may be the problem but while looking round the engine bay I notice the smell of coolant stronger at the side of the engine that the airfilter is after shining the torch I noticed some pools of coolant underneath, the part I think it's leaking from is just under the vacuum pump. Does anyone here know what the pipe is called or have a link to a replacement as I think that may be the cause of my problems
Its located under the vacuum pump and is a plastic piece bolted to the block connected to the coolant pipes.
Thanks in advance.
