[Mk4 Bora] Traction Control Light - Suspension, Brakes and Chassis - uk-mkivs
Mk4 Bora
No replies to this topic
#1 arek_p
arek_p
  • 36 posts
  • Brisbane
  • Bora V6 4motion 2.8 24v 204PS
Posted 04 March 2021 - 01:13 PM
Since I've done work to my car (pulled out dash, trim, carpet, fixed AC flaps, suspension, detailed engine bay, cleaned air box), the Traction Control Light comes on.
When car is first turned on, the light is off. Before driving, when I push the brake pedal, it lights up and stays on.
New brake light switch fitted few months ago.
Wheel alignment done after fitting suspension. Next week new tires as front left is worn....
I tried VAGCOM to adjust steering wheel position, but controller 16 gives me error "no response from controller"
I tried resetting steering wheel position sensor by turning left, right, driving straight, but no luck.
ABS light is not switched on.
No other lights are on.
Cruise control works fine.
I wonder if perhaps there's a plug I missed? Suggestions would be welcome.
Also tagged with one or more of these keywords: Mk4 Bora
