Golf MK4 Door seal clips - Interiors - uk-mkivs
14 replies to this topic
#1 goat
goat
  • 38 posts
  • UK
  • Golf IV TDI 1.9 ATD 100PS
Posted 19 March 2021 - 06:06 PM
Found water in the rear passenger footwell. The door seal rubber has come loose in a few places due to broken clips. I havn't been able to find this particular type of clip online, has anybody seen them anywhere? Or an alternative type which would suffice?
#2 ttg4l
ttg4l
  • 1002 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 19 March 2021 - 07:39 PM
Where abouts do they fit on the door?
#3 IrishBen
IrishBen
  • 48 posts
  • Ireland
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 19 March 2021 - 09:29 PM
On mine they hold a rubber weather sealing strip along the inside lower edge of doors. I remove them to access my drain holes in the doors, they're quite fragile and with mine given their age I've broken a few myself. I'm thinking to try fix with super glue cause I saved em. IF you happen to find them can ya please lemme know where you got them?
Sent from my SM-G975W using Tapatalk
#4 ttg4l
ttg4l
  • 1002 posts
Posted 19 March 2021 - 10:19 PM
https://www.ebay.co....tm/291041300994
These?
#5 goat
goat
  • 38 posts
  • UK
Posted 20 March 2021 - 11:17 AM
I should have mentioned this. As Ben described - they hold a rubber weather sealing strip along the inside lower edge of doors.
Unfortunatly these clips don't fit, I already bought and tried them. They have additional square shaped plastic bits which prevents inserting them into the rubber.
Yeah sure, will update if I find them.
#6 Burgy
Burgy
  • 177 posts
  • Surrey
  • Golf V GT FSI 2.0 150PS
Posted 20 March 2021 - 12:15 PM
https://www.vehiclec...s-vw-251823717/
#7 goat
goat
  • 38 posts
  • UK
Posted 20 March 2021 - 12:34 PM
Thanks for looking. The ends of the clip look very different and maybe too big, mine have a flat thin base to insert into the rubber, and a thin round shaped end, but the middle part of those clips looks more what I am looking for, so they might work. Have you used these yourself on a mk4, or have they been mentioned in past threads as a suitable alternative?
I've contacted the site you linked to, will update if they respond.
#8 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 20 March 2021 - 02:19 PM
Not used them, I have a mk5 I just did a internet search.
#9 IrishBen
IrishBen
  • 48 posts
  • Ireland
Posted 21 March 2021 - 12:34 PM
https://www.ebay.co....tm/292310520411
Those maybe, they look very close to. If I get a chance I'll pop one out today and slap a vernier caliper on it for some measurements.
#10 yurtesen
yurtesen
  • 1197 posts
  • Finland
Posted 21 March 2021 - 04:18 PM   Best Answer
Search for this -> 3B0839723
https://www.ecstunin...clip/3b0839723/
Edited by yurtesen, 21 March 2021 - 04:19 PM.
  • goat likes this
#11 goat
goat
  • 38 posts
  • UK
Posted 22 March 2021 - 03:16 PM
Cheers Ben. They do look like they will do the job. Found a UK seller for them, trying some other clips first, if they don't fit then I will buy these as a last attempt.
Thanks. I think this is the one, I've ordered some. It looks a bit thicker than mine, but mine might not be stock, put in by a previous owner.
#12 goat
goat
  • 38 posts
  • UK
Posted 24 March 2021 - 04:49 PM
Fitted these today, they are the correct clips. Cheers.
#13 goat
goat
  • 38 posts
  • UK
Posted 24 March 2021 - 04:52 PM
https://www.ebay.co....ic/223361436509
#14 IrishBen
IrishBen
  • 48 posts
  • Ireland
Posted 25 March 2021 - 10:12 AM
Deadly stuff man cheers! I reached out to em on eBay and they said they don't ship internationally right now (?????¡¿) so whatever my brother lives in UK so he's gonna order em and post to me.
I've a new part needing found myself, little rubber stopper located in the plastic top engine cover. Far as I can tell it just stops it vibrating when she's running.
Its 16mm (x 5mm high) dia on bottom and then ~12mm (x9mm high) up top at the narrowed part. It's 14mm long. Has no part number so I'm guessing it's probably a universal thing? ef2bbcc426b0f9b187ec73c2a23c907d.jpgb44e964dbec3f0934c07d6db2aee6ac5.jpgd2195cf2cd1689b6f81d0e268bbcf0dc.jpg
#15 goat
goat
  • 38 posts
  • UK
Posted 25 March 2021 - 01:52 PM
Ben I think your best bet is to check on a diagram:
http://www.oemepc.co...3707973/lang/e
www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOV/year/1999/drive_standart/185/hg_ug/103/subcategory/103045/part_id/3685709/lang/e
Is the part in your seccond image 028103638A?
