What have You done to Your MK5 today... - Page 39 - MkV (Mk5) Golf, Golf Plus & Jetta - uk-mkivs
1165 replies to this topic
#1141 chunk1982
chunk1982
  • 21 posts
  • Shropshire
  • Golf V SE 1.6 FSI 115PS
Posted 17 October 2018 - 09:07 PM
Fitted my GTi pedals so took the opportunity to remove and clean the throttle body at the same time. This is what 140k miles of carbon build up looks like bcad34c62e7e292c9b1e83b64b65d3ee.jpgab65a88f4f120b3681ba9bf1a9d38bed.jpgcaa87c5fd394b8ce00dd0603490d6b07.jpgcac78ef858bf436f7922b809088a5400.jpg
Sent from my EVA-L09 using Tapatalk
#1142 lukbenphi
lukbenphi
  • 146 posts
  • Matlock
  • Golf V GT TDI 2.0 140PS
Posted 05 November 2018 - 12:34 PM
Sold it,
Got 900 in end  half what I paid 2 years ago so not bad considering it wants a few bits sorting
  • thinkpad likes this
Romanes eunt domus
#1143 thinkpad
thinkpad
  • 530 posts
Posted 05 November 2018 - 04:29 PM
Sold it,
Well done! How much did you advertise it for and where?
#1144 lukbenphi
lukbenphi
  • 146 posts
  • Matlock
Posted 07 November 2018 - 11:10 AM
had it up for £950 as a start price on ebay, would of liked a bit more to cover costs of the new car and reserve was set at £1300  but got fed up of repeated  " I'll give you £250 for it and collect in an hour " type offers so let it go on end as it had been advertised once already and i wasnt paying another £17 to ebay for the privalidge
bloke was alright who bought it so its going to decent home
on one hand it was a half decent comfy  motor and has got me to work and back for the past 2 years and all over country but on flip side its cost me a fortune in parts to keep it on the road so im glad to see back of it
Romanes eunt domus
#1145 Burgy
Burgy
  • 177 posts
  • Surrey
  • Golf V GT FSI 2.0 150PS
Posted 07 November 2018 - 09:30 PM
4 New Primacy 4 tyres fitted, (the last ones were down to just over 2mm, with the winter nearly here I thought might as well do it now,) via Blackcircles,
#1146 tdimac
tdimac
  • 50 posts
Posted 14 November 2018 - 04:05 PM
Replaced second rear wheel bearing on the Ed30 to finally lose the chinook noise in the boot and replaced the high pressure fuel pump cam follower. No idea if it had been done before but only had a very slight amount of wear so doubt it's done the 83k on the clock. And then to celebrate went out and gave the beast a damn good thrashing.
Still don't know how fast the old girl will go as I ran out of safe space.
Silver mk4 1.9 ASZ 130 pd, anniversary highline clocks, retrofit cruise control, 1.8T anniversary rear bumper and milltek non res exhaust, mk1 TT alloys
Grey mk5 GTi Edition 30, stage1 remap, intake and milltek resonated cat back.
#1147 phil1964
phil1964
  • 39 posts
  • evesham,worcestershire
  • Golf Match 1.9 TDI 105PS
Posted 12 January 2019 - 12:19 PM
Did this 76f62a1c.jpgTo fit these!d959e59a.jpg00c450da.jpgAlso gave it a rather good clean!
i want to fit some dark headlights like that were did you get them from .,please,pm me details part numbers
thanks
  • macc70 likes this
#1148 thinkpad
thinkpad
  • 530 posts
Posted 20 January 2019 - 05:25 PM
Just had the OSR caliper replaced as the handbrake mechanism packed up again. Paid £85 for a refurbished caliper including fitting. The other side was replaced nearly 2 years ago. Bloody rear calipers on these are terrible because of the handbrake.
#1149 gerrywac
gerrywac
    Hang on like this MKIV thing
  • 4543 posts
  • West Yorks
Posted 20 January 2019 - 05:58 PM
Let me know price on skirts as I will buy today If that's the price! Front badge is a twist and pull technique if I'm correct? There's 3 clips u need to twist one way or the other then pop the clips out
On my 07 1.9tdi the front badge has no separate clips, they're moulded onto the back and when it's fitted to the grille they lock in place.
To remove I had to jam the handles (rubber clad) of a pair of pliers into the slots and then with a bar or beck screwdriver in the open Jaws twist the badge anti-clockwise 45deg which snaps the locking lugs and the badge can be removed
To refit insert the badge 45deg anti clockwise and then turn it the same right to a 12 o'clock position. It's on a bayonet so it won't fall out but it won't hold due to the lock lugs being snapped so you need to use a blob of hot melt glue or caulk when fitting to hold in place
Without this it is easily removed by a thief or it can rattle round and fall out.
Sent from my PRA-LX1 using Tapatalk
#1150 gerrywac
gerrywac
  • 4543 posts
  • West Yorks
Posted 01 February 2019 - 12:09 AM
Coldest day of the year so far - 4.5C jumped in my 07 1.9tdi and it started 1st turn after the glow light extinguished but then threw a stop-check coolant message and dash light.
Stopped and checked and the level was only marginally below minimum and as I had a meeting to get to I continued my journey. The light and message extinguished part way and never returned over three restarts till I got home.
When I changed my coolant 18 months ago after a run the level dropped to the min line (presumably as air in the system escaped) but I left it be and the level never changed.
I can only think that the extra cold weather was just enough to reduce the water volume enough to trigger the light. Think I'll just add a splash of pre-mix coolant tommorow.
#1151 thinkpad
thinkpad
  • 530 posts
Posted 13 February 2019 - 11:00 PM
Fitted my GTi pedals so took the opportunity to remove and clean the throttle body at the same time. This is what 140k miles of carbon build up looks like ab65a88f4f120b3681ba9bf1a9d38bed.jpg
Just cleaned my throttle body today. The pics above from previous poster was exactly what it looked like on my 1.6 FSI.
I did clean it a few years ago, although that time I made a huge booboo and tried to clean it without removing the TB. On the 1.4 / 1.6 FSI DO NOT EVER spray cleaners onto the TB whilst still on the car. It will send all the muck collected from EGR valve into the intake valves and engine. When I did this it idled very well but under load it was pinging a lot more.
This time around I took TB off and cleaned it properly with TB cleaner. Engine runs slightly better but my error from the first time has permanently clogged up the intake and no amount of cleaning will fix it unless I get it wallnut blasted or have intake valves cleaned.
Edited by thinkpad, 13 February 2019 - 11:06 PM.
#1152 ypvs
ypvs
  • 616 posts
  • N Cambs
Posted 12 May 2019 - 08:53 PM
As I've finally managed to get some photos of the car whilst reasonably clean I thought I'd do WHYDTY Mk5 in the Last Year
Purchase price was £2000 for a 100,000 mile 04 reg 140 TDI
IMG 20190512 203425
Wheel have had a quick refurbish as they had a bad case of white worm. Front wing has also been replaced, as well as the diver side door lock module. Front drop links replaced. Silver Smoothrite paint for the callipers.
IMG 20190512 203458
Front grille changed to black and a misty headlight polished up. Philips Vision Plus bulbs for main, dip and side lights. Also for Puddle lights.
  K+N filter
IMG 20190512 203541
Badge was suffering white worm so replaced with a Mk4 badge I had. Rear lights lightly tinted with film. Fog light swapped with Euro reversing light and red  LED. Mesh clip-in sun shades
IMG 20190512 203611
LED display swapped as it was fading in hot weather. Window, lights and CD switches replaced with chrome trims. Cherry red hazard from China. GTi-style aluminium pedal covers. Black rear view mirror. Foot well lights in rear. USB socket in centre console
#1153 dave234
dave234
  • 1 posts
  • North London
  • Golf V Plus Sport 1.6 FSI 115PS
Posted 16 May 2019 - 08:21 AM
I didn't really do much but the car past its mot. Only the cloudy head lights whrre advised. Not bad for a 55 plate 176k 1.6fsi
#1154 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 26 May 2019 - 10:04 AM
Fixed the Bonnet catch, the problem appear to have been caused by a build up of crud in the mechanism. Then a wash & polish.
47935044541_937a85e13a_k.jpg_BPB6248 by Paul Burgman, on Flickr
#1155 johnbee
johnbee
  • 2 posts
  • uk, cornwall
  • Golf V S 2.0 SDI 75PS
Posted 31 May 2019 - 07:16 PM
just killed my 2007 2.0 SDI - spun No.1 main bearing.
Crank and block U/S main cap too heavily worn. Journal - well not much left!
Engine ran fine with a small knock, took the sump off to investigate and found nasties.
#1156 TomasLT
TomasLT
  • 4685 posts
  • northern europe
Posted 05 June 2019 - 09:53 AM
Change oil, filter much?
#1157 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 08 June 2019 - 01:42 PM
With the MOT in a couple of months, thought that I should bet some of the advisories cleared up. Mate did the work inc replacement CV gaiter which had failed, & replaced the lower arms & bushes. It hasn't had the tracking done yet, but the self centering is much better.
http://48024355472_1ffef87a53_k.jpgNew Suspension by Paul Burgman, on Flickr
  • Rimvyz likes this
#1158 Rimvyz
Rimvyz
  • 7 posts
  • Crawley
  • Jetta Sport 2.0 TDI 140PS
Posted 27 June 2019 - 04:50 AM
Replaced old leaking air con condenser, replaced old air con hoses, fully fixed air con, ready for summer!dae7ed485dc0366dd24c7d16b62e73f4.jpg
Sent from my SM-G975F using Tapatalk
#1159 AdamF80
AdamF80
  • 5 posts
  • Manchester
Posted 20 July 2019 - 07:52 AM
Well .
I bought the car under a week ago and so far have ordered
. Front shocks and springs
. Rear springs
. Passenger side window regulator
. Four speed blower resistor
. Front bumper
. Bonnet strut
Of this the blower resistor has yet to arrive .
I have also changed the cabin filter and what an easy job that was compared to the last car.
Sent from my SM-G960F using Tapatalk
#1160 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 20 August 2019 - 08:38 PM
Put mine through an MOT this morning, pass with only observation was brake flexies will need replacing soon. However, perversely 2 hours later it throw a defective bulb warning, just glad it was post MOT!
#1161 deanrodden4
deanrodden4
  • 6 posts
Posted 21 August 2019 - 02:45 PM
Gave her a wee clean
Also looking for info regarding my clocks if anybody could help would be much appreciated7d33ed304d820742f41f8baad2a3f6df.jpg
#1162 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 22 January 2021 - 10:26 PM
Purchased a memory saver, replaced a dying battery, ordered a replacement set of gas struts for the bonnet & tailgate. However Royal Mail sent my struts to the other end of the country, realised they'd flipped up, so sent them to the other end of the country again, so not holding my breath as to when they will actually arrive.
50863789608_56bd920498_h.jpgMemory Saver by Paul Burgman, on Flickr
#1163 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 27 January 2021 - 03:30 PM
Replaced the Tailgate & Bonnet struts, as they eventually arrived, bloody Royal Mail!!!! Anyway I ordered two for the tailgate & one for the bonnet, however they have shipped two bonnet struts (only charged me for one though) so if anyone needs one, they are welcome to have it if they want to collect it from Guildford.
50881555432_304b1e169d_b.jpgIMG_2415 by Paul Burgman, on Flickr
50881452381_b60be3838c_b.jpgIMG_2412 by Paul Burgman, on Flickr
50881452416_130c3cdbce_b.jpgIMG_2410 by Paul Burgman, on Flickr
50881452476_0051d0abdb_b.jpgIMG_2408 by Paul Burgman, on Flickr
Edited by Burgy, 27 January 2021 - 03:30 PM.
#1164 Burgy
Burgy
  • 177 posts
  • Surrey
Posted 12 February 2021 - 03:25 PM
After replacing the bonnet gas strut and the tailgate ones, I also replaced the bonnet insulation as it was falling apart. £40 odd quid from Lithuania, not sure what the fit should be like as the original was literally held on by the clips, but it seems ok.
50936109352_762c683aec_b.jpgbonnet by Paul Burgman, on Flickr
  • gerrywac likes this
#1165 thinkpad
thinkpad
  • 530 posts
Posted 25 February 2021 - 03:42 PM
Car went in for an MOT earlier and passed with two advisories / minor defects relating to these crappy plastic headlights becoming cloudy. I cleaned it a couple of years ago as it had failed on it then but it looks like I'll have to get that sorted again before next MOT.
Happy with another 12 months without any expenditure (although I did replace the rear left hub and ABS sensor a couple of months ago for around £100).
Edited by thinkpad, 25 February 2021 - 05:17 PM.
#1166 Mmalkie
Mmalkie
    Dinny gees any o yir pash !
  • 1196 posts
  • Sunny Scotland
  • Other Models
Posted 03 April 2021 - 08:08 PM
Having been thru the pain of a drained battery / christmas tree dashboard & potential MOT failure on the wife's beloved Mk5, In the last 7 days I spent £310 on having a new ABS sensor fitted, then a Replacement bearing hub for rear drivers side (as it was the sensor ring, not the sensor), had the front alignment done, got all the faults cleared & got it MOT'd.
Now Mrs wife wants it 'Looking' like a complete car, as the fuel filler flap locked shut about 2 yrs ago, I frigged it to get it open (knackering its ability to close) & about 6 months ago some toe-rag kicked the hole flap off...
Anyway, today's task was fitting a new badge & front grille, (after smashing thru said grille in August last year, as the bonnet latch cable 'snapped'), as well as removing the towing eye from the Front drivers side & refitting the lower grille element.
I've yet to fit the 'pins' that go into the boot lid inner trim panels that allow you to suspend the parcel shelf from, so it will go up when the boot is opened, as well as the fuel flap solenoid (which i can't fit till I get a replacement fuel filler flap assembly in tornado red). E-Bay has about 10-15 up for grabs, with at least x3 of those being useless to anyone, as the plastic catch the keeps the lid shut / locked, has been sheered off ! of the other, their are about x7 Silver ones...
