Using the reg number to obtain the chassis number you get this
WVWZZZ1JZZB114712
BUT it does not show on the ETKA (VW database) as being a valid chassis number so it COULD be an import but cant see what the chassis number does not show regardless if it was an import or not [8-)]
so i would say something is not quite right somewhere
this is the data from a VRN check
VOLKSWAGEN |
GOLF GT TDI |
20020509 |
False |
01781 |
13 |
20020412 |
2002 |
False |
False |
False |
SILVER |
UNKNOWN |
NOT KNOWN |
WVWZZZ1JZZB114712 |
3 DOOR HATCHBACK |
M7 |
744 |
UNKNOWN |
190 |
False |
False |
EDIT if i change the 2nd Z in the chassis number to a 2 so it would read WVWZZZ1JZ2B114712
The it shows up on ETKA as a 1.8TURBO AUM with a gearbox code of EVS date of manufacture 12.02.2002
Hope that helps and think it is just a SPELLING MISTAKE through the DVLA system but would double check that to be 100% sure
